re-flash Check
Ewwgoblins
re-flash Check
Post by Ewwgoblins »
I needed to see if my ECU has been reflashed.
37820-PNF-A04
2091-400237
Thanks!
Re: re-flash Check
There is no record of that ECU being reflashed.
Ewwgoblins
Re: re-flash Check
I have one more.
37820-PRB-A05
2068-512131
I am purchasing this unit for my 02 civic si. It should be kpro'ed, but im not sure of the version.
Thanks!
Re: re-flash Check
You will have to look at the serial number on the K-Pro itself inside the ECU.
Ewwgoblins
Re: re-flash Check
Okay. I appreciate your help!
