Support for 05 CR-V
Boosted05CRV
Support for 05 CR-V
Post by Boosted05CRV »
Hello. I have an 05 MT CR-V with PPA-A23 ECU. I know that the 02-04 CR-V can use kpro. Does Hondata have anything to support the 05 as it is drive by wire? If not directly for the 05 then are there some work arounds? Maybe other ECUs that could be swapped? Preferably not with deleting the dbw. Any help is greatly appreciated. Thanks.
Re: Support for 05 CR-V
Sorry, we do not offer anything for the 05 CRV
danielhilgersom
Post by danielhilgersom »
Hi,
I have a Honda CR-V 2002-2004 but cannot find which product will fit.
Please inform me.
Thanks!
Is it an automatic?
danielhilgersom
The CR-V 2002-2004 is a European with Manual transmission.
I'm also curious if there is a ECU tuning solution for the CR-V 1997-2002 European version with manual transmission.
Cannot find it on the Hondata website.
I'm electrical engineer so some modification should not be a problem but I prefer a plug and play solution.
Post a picture of the inside of these ECUs you are referring to.
danielhilgersom
Thanks for the reply.
The ECU of the 2002 -2004 car is the same as on this ebay link:
Please post actual pictures of the exact ECU in question.
sass
Post by sass »
For the european market was not produced CR-V with the engine 2.4
only 2 liters from ECU 37820-PNL-G01-02 M/T
Cr-v RD8+K24A2turbo+Kpro V4 prb+NPR3/6Speed+ТС+ HFS4 v3.2.
DynoWheel = 472kW / 589 N.m
HRX One Mile Challenge = Max Speed 282km
Known as Sniper
ef9b16a1
Post by ef9b16a1 »
i have a turbo crv 02-04 , you can use a pra ecu if you already have a kpro in it , you just cant control the intake flaps in the plastic manifold with the pra in the k20a3 (i think) 150ps engine , internally the oem ecu is same layout/chipset as a pra , so you can also install k100 kpro etc
danielhilgersom
Thanks for the response!
It's indeed a 2 liter engine :)
sass
Post by sass »
ef9b16a1 wrote: Sun Mar 11, 2018 10:40 am i have a turbo crv 02-04 , you can use a pra ecu if you already have a kpro in it , you just cant control the intake flaps in the plastic manifold with the pra in the k20a3 (i think) 150ps engine , internally the oem ecu is same layout/chipset as a pra , so you can also install k100 kpro etc
You're wrong. PRA ecm will not work on CR-V 05-06.
https://www.hondapartsnow.com/parts-lis ... -body.html
Electronic throttle is not compatible with PRA ecm.
Known as Sniper
