Switching from Narrowband to Wideband on analogue input
mikehhhhhhh
Post by mikehhhhhhh »
Can someone tell me if I have interpreted the Closed Loop settings correctly.
I currently have a PRA with Narrowband sensor.
My interpretation is that I can replace that narrowband sensor physically with something like the PLX or Innovate LC-2, wire it up to an analogue input using the appropriate conversion setting then switch the closed loop operation to use the wideband without any additional changes or tuning? The wideband replaces the functionality of the narrowband completely, only it can now give me full wideband datalogging capabilities for AFR?
Re: Switching from Narrowband to Wideband on analogue input
What is the serial number of your K-Pro?
