Bug with Undo/Redo in Tables?
Posted: Wed Feb 21, 2018 12:50 pm
Not sure if this is by design or a know bug, but i have been seeing really strange behaviors when using Undo/Redo edit functions and the Fuel tables.
There are several ways to reproduce the issue and different behaviors happens, but for instance, a clear one:
1) Start a new calibration, select itr-stock.skl map, go to primary fuel tables
2) select any cell and decrease or increase (ctrl+d / ctrl+i) its value 2 or more times
3) move to another cell and do the same, modify the value 2 or more times
4) press ctrl+z or do Undo, both cells get modified, not just the last one, and if you redo back only the last one get redoed.
This behavior seems to change a LOT with different maps, if you do the SAME steps but with stockd16.skl map the whole col6 gets modified.
Hope this helps, its kind of annoying when you modify one cell and then press ctrl+z and you see 10+ more cells get modified
Tested in v2.6.6.0
Tested in v2.6.6.0
