Installing Hondata Mobile on your 10th gen Civic radio/navi
What this does
The radio / entertainment system / navi in the 10th gen Civic uses an Android based device, and runs Android Apps. From the factory the radio only accepts Honda authorized Apps. This process unlocks ('roots') the Android system so that the Hondata Mobile Android App can be installed on the radio.
Warning: this process alters your factory radio at a low level and has a risk of disabling your radio and may also affect your factory warranty options with the radio/navigation.
What you need
USB A to A cable
USB flash drive
Laptop computer
FlashProManager V2.9.4 or later
Procedure
A) Enable developer mode
1. Start with the ignition in accessory mode
2. Press home, then 'Settings', then 'System', then scroll all the way to the right and then all the way down to 'Detail Information'.
3. Scroll to the bottom and press 'Android Information' or 'About Device'.
4. Press 'Build Number' eight times. Under 'Kernel Version' a button appears 'Please enter a password'.
5. Determine if your radio firmware is 2016-2017 or 2018+ by looking at the date after 'Kernel Version'.
6. 2016-2017 kernel versions: Scroll down, press 'Model Number', then 'Kernel Version', then 'Android Version' then 'Baseband Version'. Developer mode will be enabled.
7. 2018-2019 kernel versions: Scroll down, press 'Kernel Version', then 'Model Number, then 'Build Number' then 'Status'. Developer mode will be enabled.
8. Press the Back button once and then press 'Developer Options'.
9. Scroll to 'USB Debugging' and enable it.
B) Change the USB mode
1. 2016-2018: Hold the Brightness button (physical button on the top left), Audio button and Menu buttons down all at once. A menu will appear with two large white buttons.
1. 2019: Hold the Brightness button (physical button on the top left), Phone button and Audio/Volume buttons down all at once.
2. Select the bottom white button 'Detail Information & Settings'.
3. Hold down the Menu button (2019 Civic: Phone button) until another menu appears.
4. Hold down the Home button for approximately 15 seconds. There will be 3 rapid beeps after a few seconds, then another beep after 10 seconds. A new menu appears.
5. Change the USB role from Host to Device.
C) Root the radio
1. Download the Honda Hack tool from https://github.com/codeage/root-honda/b ... p?raw=true
2. Unzip the hack tool on a laptop. Note that all anti-virus software will complain that this is a 'hack tool'.
3. Using the USB A to A cable connect the laptop to the USB port with the smartphone picture on it.
4. On the laptop run the Honda hack tool. It will connect to the radio automatically.
5. On the laptop click on the 'Root' button.
6. After rooting is complete unplug the laptop from the USB.
7. For some models the radio the radio will reboot automatically, for other vehicles the radio will flash every 10 seconds or so. In this case, switch off the ignition for 30 seconds and then switch on the ignition to accessory.
8. The radio should show the Honda logo for 1 minute while rebooting.
D) Install the Hondata mobile App
1. Download the Hondata mobile APK file and save onto the USB flash drive.
2. Plug the USB drive into the center console USB port.
3. On the radio press Home, then 'App List' (some models) or the button with six squares (other models).
4. Run the 'Honda Installer' app.
5. Select 'Install An App'.
6. Press the top backslash or '..' to go backwards and then scroll down to 'usbdrive2'.
7. Select the com.hondata.hondatamobile.apk file.
8. The Hondata Mobile App will be installed.
9. Press and hold the Audio button for approximately 10 seconds and then select Yes to reboot the radio. This takes about 1 minute and the Honda logo will show when rebooting.
E) Linking to FlashPro
1. Make sure that you have updated the FlashPro firmware using FlashProManager V2.9.4 or above.
2. Switch the ignition to run or start the engine.
3. Press Home, then Settings, then Bluetooth, Devices then Search for Devices.
4. The FlashPro will appear as a MAC address (8 pairs of numbers separated by colons).
5. Pair to the FlashPro. If you have changed your code from 0000 then you will need to enter it.
6. Press Home, then App List and then Hondata Mobile.
7. Click to lightening bolt to connect. The FlashPro will appear as 'FlashPro'.
8. Enjoy running Hondata Mobile on your 10th gen Civic.
Credits and links
Software
Hondata Mobile
https://www.hondata.com/updates/link.php?app=dash
USB A to A cable
https://www.hondata.com/products/usb-a-a
Instructions & Credits
https://forum.xda-developers.com/androi ... 7-t3621582
https://forum.xda-developers.com/androi ... a-t3487644
Some anti virus software will give a warning that the HondaHackv2.0.exe contains a trojan. Technically it does. The file that triggers the warning is 'dirtycow', which is listed as an 'android hack tool', which it is. The file is not a Windows file so cannot harm a Windows PC. However vigilance should be maintained that other files in the HondaHack.zip do not contain malicious software. If you are not technically savvy and comfortable installing and running this type of software then we recommend you do not do so.
high718
Re: Installing Hondata Mobile on your 10th gen Civic radio/navi
Post by high718 »
i have a 2018 civic type r. i did everything in the instructions to try to connect my headunit to the flashpro when i got to add device it says type 0000 and then it says unable to connect. on the flashpro on the pc ive clicked bluetooth on and made sure it has the correct 0000 pin but still wont connect.
can you connect to a phone or other mobile device?
high718
Post by high718 »
yes i can connect to my iphone via bluetooth. But when i comes to the head unit as the pin code 0000 pops up then says unable to connect. on my pc in the bluetooth setting of the flashpro bluetooth is enabled and the pin is 0000. But when i try to connect it says unable to connect.
You must pair it outside the app in the operating system first.
high718
Post by high718 »
yes i know im trying to pair it to the car first and thats where its asking for the 0000 pin.
high718
Post by high718 »
when i get to step 3 of this step the flashpro comes up on the bluetooth/wifi setting on the headunit.
i click the flashpro after it scans, it then tells me to type 0000 on the device, then says unable to connect. i never changed the code on the headunit its still 0000.
Can the head unit connect to any other Bluetooth devices?
high718
Post by high718 »
yes my headunit auto connects to my phone every time.
delete all paired devices and try pairing it again to the head unit.
Jun43
Post by Jun43 »
When did you buy your Type R? They may of updated the headunits with the rest of the 2018 Civics where it doesnt allow you to pair it
high718
Post by high718 »
I purchased mine may 29th 2018.
藤原文钟
Post by 藤原文钟 »
Hondata mobile APK? where is this document? please answer me
Carlosrosas1979
Post by Carlosrosas1979 »
Would this hack work with an Honda Accord 2020?
