Does Flashpro affect sensors?
Civic 2016+ 1.5 Turbo
sunworld23
Post by sunworld23 »
I used the +6 psi CARB flash for my 2016 1.5T CVT Civic Touring. Starting the car for the first time, I got an error that the Collision Mitigation Brake System was not working. After driving for a bit, the error icon went away. I have not seen the error since.
I'm curious is the CMBS affected by the new ECU flash? Are any other sensors affected? I'm very pleased with the boosted performance so far
Jun43
Re: Does Flashpro affect sensors?
Post by Jun43 »
no
gtman
Post by gtman »
You should be fine. When you flash for the first time errors pop up all over the dash. Usually they disappear when you start the car up. I guess that one error took longer to disappear. Its a normal part of the ECU retune.
I also have the Carb Flashpro and just flashed the +6 tune. It's a nice bump in power in high throttle situations.
sunworld23
I figured as much. Thanks! I've noticed myself looking at the speedometer more because it's too easy to go fast now haha
Civic4Life86
Post by Civic4Life86 »
Yes all my sensors are on and they wont go away. Does anyone know how to erase these codes. Also my idle is very jumpy and the car shakes. Around 1600 rpm the car just wants to spudder then after that it runs hard. Any suggestions?
Civic4Life86
Idling problems and dash sensors all on?
Car seems to be shaking during idle and low rpm below 2000. Anyone have similar issues or know what to do?
What error codes are you getting?
Re: Idling problems and dash sensors all on?
Are there any error codes?
Civic4Life86
I dont have a code reader and I'm not familiar with hondata yet. Every sensor in the dash is constantly on
Civic4Life86
How do i find the codes
Civic4Life86
I've been driving over 5,000 miles since the Flash and all my errors are still there
To check error codes use the FlashProManager software. Note that this will only show ECU related errors.
Return the ECU to stock and see if the errors come back.
