Can PRA ecu use wideband as primary?
JackSVM
Post by JackSVM »
As the title suggests. I have a PRA ecu on my ep3 and it uses a narrowband lambda sensor from the factory. Can it be made to use a wideband lambda as its primary?
Re: Can PRA ecu use wideband as primary?
What version K-Pro do you have?
JackSVM
Post by JackSVM »
V4
Yes it can be used to input a wideband signal to run closed loop.
http://www.hondata.com/help/kmanager/an ... b=wideband
This can only be done using a V4 K-Pro.
JackSVM
Post by JackSVM »
Aa ok sweet. I already have my wideband on analogue 0 for datalogging but how do I change it over so the ecu uses this input for its lambda readings and to use closed loop?
You will see it in the closed loop tab of the parameters window.
JackSVM
Post by JackSVM »
Ok thanks 👌🏻
