2014 civic si won’t start
gabevaldez97
Post by gabevaldez97 »
I just recently purchased hondata flashpro in hopes to tune my car a little, I have an rbc swap, prl intake and a skunk 2 exhaust, I loaded my first calibration thinking everything was good, but now my car won’t start and I have no idea why, I’ve tried loading the stock ecu back but to no avail, please help me
Re: 2014 civic si won’t start
With everything connected and the key in the on position, what does it show in the lower left hand corner of the software?
gabevaldez97
It shows all the connections are good
Go to the online menu and try returning the ECU to stock.
gabevaldez97
I’ve tried this and it still won’t start
Is it cranking at all, or is it not even attempting to start?
gabevaldez97
It’s cranking and sometimes will start but not often will it actually start it’ll just crank for a little then die and when it does start it struggles to do so
When was the last time that it started and what have you done since that time?
gabevaldez97
I believe Sunday was the last time It started and after I turned it off and tried to start it again but to no avail, I haven’t done anything since
I would recommend that you return it to stock and unlock the FlashPro and get the vehicle to a Honda dealer for diagnostics as to why it will not start.
gabevaldez97
Would it matter that my car has some after market parts
It could be a contributing factor.
gabevaldez97
i meant would the aftermarket parts be a problem if I took it to Honda, the car ran fine before I used the flashpro on it
It ran with all those parts installed?
It is up to you what parts are installed when you take it to the dealer, but if the ECU is returned to stock and still will not start with all stock parts then there is some other problem that Honda will need to address.
gabevaldez97
yea the only thing ive done to this car since ive owned it was the hondata
