wide band best ecu pin
Posted: Mon Mar 19, 2018 9:01 pm
by erovalles
Probably a dumb question but just wondering, the flash pro help section mentions the pin information for the 2012-2015 civic r18 would my 15 si be the same? Oh and also what pin did you guys use for your wide band? isn't it just plug and play to the regular o2 sensor connector? i'm thinking of buying the AEM Wideband UEGO Air/Fuel AFR Gauge.
Re: wide band best ecu pin
Posted: Tue Mar 20, 2018 10:04 am
Pin details can be found in the help file:
https://www.hondata.com/help/flashpro/e ... ectors.htm
You can use either input listed, but it is for datalogging only and will not allow you to run in closed loop.
Posted: Wed Mar 28, 2018 8:45 am
by erovalles
Okay so it’s for data logging only and won’t allow me to run in closed loop ? So after making accurate afr adjustments I could just disable it ? And run my car normally and more efficient ? Or does it permanently disable closed loop until it’s taken off
Posted: Wed Mar 28, 2018 9:33 am
You can only run closed loop using the OEM wideband that comes with the vehicle. There really is not a need for an aftermarket wideband in these vehicles.
