2017 Civic SI E85 flash
htec17
Post by htec17 »
Can I flash the flex-fuel tune and drive the car or do I need to get the sensor?
2020 civic si,flash pro,afe intake,afe exhaust,prl intercooler,acuity short shift and eibach springs
Re: 2017 Civic SI E85 flash
I would wire the sensor in first.
htec17
Post by htec17 »
Ok thank you
htec17
Post by htec17 »
chevy uses a flexfuel sensor on most of there vehicles.Would that be ok to us?
You need both the sensor and the electronics which converts the PWM signal from the sensor to 0-5V.
htec17
Post by htec17 »
SO THE AFTERMARKET SENSOR COMES READING IN VOLTAGE THE CHEVY DOES NOT
Yes. Aftermarket is actually the sensor + electronics to convert the signal.
