2007 TSX DBX rev hang
9000revs
Post by 9000revs »
My car is stock and I am looking to eliminate DBW rev hang. Should I use the "stock equivalent" or "base map" tune? What other changes do I have to do to eliminate/reduce rev hang?
Do I uncheck the following:
"1st gear throttle dampening enabled"
"Overrun throttle opening enabled"
Thanks.
Re: 2007 TSX DBX rev hang
I am not aware of the TSX having any issues with "rev hang".
9000revs
Post by 9000revs »
Yes they do.
9000revs
Post by 9000revs »
In fact, you mentioned some settings on this thread viewtopic.php?f=37&t=19201.
I am trying to figure out what the overrun fuel cut delay should be set for this MY TSX. Thanks.
Since it is adjustable you can try different settings and see what works best for you.
9000revs
Post by 9000revs »
I tried 110,80,60,60, 40 and the first and second gear still seems a bit jerky. I am planning lower the values a bit. 3-6 gear feels great.
9000revs
Post by 9000revs »
Anyone who has been able to reduce "rev hang", please post the settings used. Thanks.
coventsm
Post by coventsm »
I'm interested in this too, I'll search around on tsxclub.com and see if anyone has a solution.
coventsm
Post by coventsm »
