AEM Wideband settings
hondaracing84
Post by hondaracing84 »
I have the AEM X-series wideband. In the parameters I tried to set the voltage settings for it. What I found was the setting should be (.5v = 8.50; 4.50v = 18.00; 4.50v = 18.00) But when I put in the settings it changed each one up by .01v. So the settings it forced me to do is (.51v =8.50; 4.51v = 18.00; 4.51 = 18.00). Is this going to be a problem, or is there a way to fix it to set it correctly?
Re: AEM Wideband settings
It shouldn't really matter, but you can always enter them slightly lower so they save correctly.
hondaracing84
I tried to enter .01 less but it rounded down to .49v instead. So I just left it at .51v. But as long as it doesn't matter, then Im good.
