K-Pro 4 High speed fuel auto tune ITB's
RLM Dan
Post by RLM Dan »
Hi,
I have a Euro EP3 type R on a K-pro 4. Don't have serial numbers etc with me as not with the car.
It is running on a set of ITB's an has a good base map with alpha n etc. Also has an AEM wide band that is wired in and working.
I have been using the auto tune to refine the map, it is working perfectly for low speed fuel, making some changes and now the map is good with low speed fuel. As soon as I go into high speed fuel/v-tec the auto tune does not make any changes no matter whichever options I check.
Feel like I am missing something obvious that will be related to the fact it is on throttle bodies and using map for TPS etc. Can anyone point me I need the right direction please?
Re: K-Pro 4 High speed fuel auto tune ITB's
You need to post the Calibration and a datalog of you trying this so that we can see what might be going on?
