TPS issue?
darren
TPS issue?
Post by darren »
Seem to be having an issue with my tps in s300, or I'm being stupid... anyway, i can set the minimum and maximum reading in the tps tab, and it reads 0-100%, perfect.
The problem is the high lighted cells in the fuel and ignition tables don't match the datalog.
For example, I'm cruising at 4% tps, and the highlighted cell would be in the 6% column. Another one would be on decel, 0% tps in the log, but showing 2 or 4% in the fuel/ignition table
This is an itb set up.
Any help would be great, Thanks
Re: TPS issue?
In the TPS tab of parameters, what do you have the MAP value with throttle fully closed and open values set to?
darren
Re: TPS issue?
Post by darren »
Fully closed 1, and fully open 100.
On idle, my map is 44kpa, i did enter 44 in the fully closed box, but TPS and load site still didnt match
Re: TPS issue?
Post your calibration and a datalog showing the issue.
darren
Re: TPS issue?
Post by darren »
Attached is a short datalog, and the calibration.
The cal is work in progress, just a rough starting point to get it up and running.
You can see the issue I'm having tho
