full throttle shift
noobroster
full throttle shift
Post by noobroster »
if the calibration on the +9 psi limits the fts limit at 5100rpm can i change that to 6000rpm safely or its just where they set it?
Re: full throttle shift
You can change it to whatever you want as it is fully adjustable.
