no start with 4 bar map sensor
redfg4si
Post by redfg4si »
just installed cte supercharger with a hondata 4 bar map and with the 4 bar the car will crank fire once and not start. car will start with the sensor unplugged but idle high. with the stock sensor the car starts right up and drives fine. tired a brand new hondata 4 bar and the car will still not start.
Re: no start with 4 bar map sensor
What does the sensor read with key on engine off?
What injectors are you using?
redfg4si
Post by redfg4si »
using 1000cc DeatschWerks injectors. will have to check what the sensor reads and get back to you, and do you mean the reading in flashpro or voltage?
the reading in FlashPro manager when datalogging.
