2018 Civic Hatchback Sport
Holy Peanuts
Post by Holy Peanuts »
Hi,
I am from Canada. Which Flasher would be the one for my vehicle?
Also, is their any possibility of damaging the engine by using the flasher?
I'm new to this so heres to learning! :)
Re: 2018 Civic Hatchback Sport
What is your ECU part number?
We have not seen any engine damage when using the built in calibrations.
Holy Peanuts
Where is the ECU number located? I looked for it yesterday night and couldn’t find it
On the ECU, in the engine bay. The part number starts with 37820-
Holy Peanuts
I need some help locating it. Where’s the ECU?
The engine bay lohas is like this
https://www.openroadhonda.com/assets/st ... 640_25.jpg
Jun43
Post by Jun43 »
to the right of the air box
Holy Peanuts
Air box being the thing middle up front?
ECu would be between that and the fuse box? The thing with the 2 gray clips on top? I don’t see a serial number anywhere on that.
Jun43
Post by Jun43 »
its on the left side at the bottom side panel of the ecu.
might have to take the airbox off
Holy Peanuts
Found it!
37820-5AN-C15
Jun43 you are a boss of bosses, thank you.
That ECU is supported.
Holy Peanuts
Thank you spunkster.
I’m leasing the car. Would you recommend I don’t use the flash pro in that case?
My wife is a little nervous about it and I’d like to ease her mind
Holy Peanuts
Basically she’s concerned about voiding the warranty and causing additional wear to the engine or parts connected to it.
Also, is it easy to revert to stock settings for the ECU for when we return the car?
This is a decision that is completely up to you.
It can be returned to stock at any time.
Holy Peanuts
I understand that.
I’m looking for an experienced, professional opinion.
OldBut
Post by OldBut »
Same question, for 2019 Civic Hatchback Sport Touring. ECU is 37820 SAN LJ1, if I read it right
And same question re effect on warranty, if flashing from the CARB limited Hondata unit.
