06 civic si knock counts with flash pro
mike_low_baby
Post by mike_low_baby »
been messing around with a map for awhile I just cant get cyl 3 to stop knocking highly.. already added fuel and retarded timing any help appreciated I could send a datalog if needed thanks in advance.
Re: 06 civic si knock counts with flash pro
Do you have mechanical changes (eg header)? They often cause knock noise.
I'm not sure how long it takes to get 75 knocks but if it is a short time then I'd consider getting the injectors tested. You could also swap #2 and #3 injectors and see if the knocks switch cylinders.
