06 civic si knock counts with flash pro
Posted: Thu Apr 26, 2018 1:53 pm
by mike_low_baby
been messing around with a map for awhile I just cant get cyl 3 to stop knocking highly.. already added fuel and retarded timing any help appreciated I could send a datalog if needed thanks in advance.
Re: 06 civic si knock counts with flash pro
Posted: Wed May 02, 2018 8:40 am
Do you have mechanical changes (eg header)? They often cause knock noise.
I'm not sure how long it takes to get 75 knocks but if it is a short time then I'd consider getting the injectors tested. You could also swap #2 and #3 injectors and see if the knocks switch cylinders.
