Edit maps/ rev hang/ no lift shift
Civic 2016+ 1.5 Turbo
Brayscivic
Post by Brayscivic »
New to flashpro.. how do you select "no lift shift" and get rid of rev hang. I've looked at the +9 psi with mishimoto intake calibration and I don't see how or where to edit this. I've uploaded the +9 psi calibration but now that I've brought the computer back inside to view everything, I don't see any where for no lift shift and fixing of rev hang. I hear of the gains with it but can't find no explanation anywhere on how to do it. Please help. Thanks
Jun43
Re: Edit maps/ rev hang/ no lift shift
Post by Jun43 »
No lift shift is under rev limits
to reduce rev hang- you would lower the value under overrun fuel cut delay under FUEL
Brayscivic
Awesome.. thank you. Is there a value I should lower it to to be exact. Like an exact number you've done?
Jun43
Post by Jun43 »
10
Lilwonton17
Post by Lilwonton17 »
Jun43 wrote: Sat Apr 28, 2018 8:05 pm10
How does the car feel with 10 across all gears?
Jun43
Post by Jun43 »
Lilwonton17 wrote: Wed May 23, 2018 10:55 pm
it runs fine
Rev hang delete is out on the latest software
Lilwonton17
Jun43 wrote: Thu May 24, 2018 9:52 am
it runs fine
I saw that and that means we don't need to adjust the overrun fuel cut delay? Since we can just go on the mod list and install the rev hang delete onto the map
