cpr wiring
gotjaydee
cpr wiring
Post by gotjaydee »
in the instructions it says to use a22 for the icm wire for the cpr kit, but in the diagram it shows to use a21, is there a difference or will either one work?
Re: cpr wiring
Either can be used as they go to the same point inside the ECU.
gotjaydee
Re: cpr wiring
Post by gotjaydee »
thank you for the response
