Skunk2 Intake Tune 09 Si
Yungtempo
Post by Yungtempo »
I recently installed my Skunk2 Intake along with a Hondata basemap. No matter what intake calibration I use it ends up running lean. It's a 3.5 inch diameter cold air intake and if anyone could help me out it would be greatly appreciated.
Re: Skunk2 Intake Tune 09 Si
It sounds like it will need additional tuning on the dyno. You should discuss this issue with your tuner.
Yungtempo
Post by Yungtempo »
In case anyone has the same problem, I didn't have race tunes checked and was only choosing MAF based tunes. The intake is too big for the MAF to compensate so you have to run it on a MAP based tune. After I did that the A/F ratios were much better.
dfon
Post by dfon »
so what tune did you use and where are your a/f at now?
