Posts: 10665 Joined: Thu Aug 15, 2002 12:13 pm
Post
by Hondata » Fri May 04, 2018 3:21 pm
Changes from 3.0.3:
[2016+ Turbo Civic] Fixed some calibrations not showing ethanol input parameters.
[2017+ Civic Type R] Added support for model 5BF-X03
Changes from 3.0.2:
FlashPro firmware updated to version 135
Changes from 3.0.1:
Fixed CARB calibrations not retaining CARB status between saves.
[2017+ Civic Type R] Added support for models 5BF-E03, 5BF-J03, 5BF-Q13, 5BF-M03
[2017+ Turbo Civic, 2017+ Civic Si and 2018+ Turbo Accord 2.0] Increased TC max boost tables for all starting calibrations
[2017+ Civic Si] Added modifications support, and ability to close throttle when shifting (rev hang)
[2017+ Civic Si] Added support for new model 5AM-M03 - Brazil
[2016+ Turbo Civic] Added support for new model 5AA-A11 - United State
Download
here
We've added some of the 2017+ Civic Type R international ECUs. More coming soon.
For all of the the 2016+ turbo Civics we have added the ability to close the throttle when shifting ('rev hang').
2018civic
Posts: 1 Joined: Fri May 04, 2018 9:23 pm
Post
by 2018civic » Fri May 04, 2018 9:31 pm
I tried downloading the new software but it seems the link is broken.
gtman
Posts: 61 Joined: Tue Jan 30, 2018 12:50 pm
Post
by gtman » Sat May 05, 2018 5:40 pm
I have a 2017 Civic EX-L turbo running the +6 Carb tune. If I update to the newest software, what exactly will this change do?
Jun43
Posts: 245 Joined: Mon Aug 01, 2016 2:59 pm
Post
by Jun43 » Sat May 05, 2018 6:09 pm
gtman wrote: Sat May 05, 2018 5:40 pm
nothing if you aren't getting the overboost CEL limp mode but you should always be on the latest revision
gtman
Post
by gtman » Sat May 05, 2018 6:41 pm
Thanks. That's what I thought. I'm working on adjusting boost and torque just a bit beyond the base +6 tune at higher RPM. Sort of like a +7.5 type tune. I upped the boost table above 3500 by 3% and put torque at 270nm above 4000.
myuser
Posts: 79 Joined: Sat Jun 27, 2009 6:55 am
Post
by myuser » Sat May 12, 2018 10:56 am
Hello,
For the calibrations for the Civic Type R (2006-2011), FN2 and FD2 some columns are not visible if we select Show all Columns in the Options menu.
For example in FN2 calibration, affect only the tables for Knock sensitivity and retard, they show only 10 columns.
The Knock ignition limit (High and Low) have 20 columns max wich is correct.
In the FD2 only shows 10 columns, is this correct for FD2?
Notice that in CivicSi all the 20 columns are available.
Please remember to make the columns available in the next release.
Thanks Hondata.
Keep up the good work :)
Post
by Hondata » Sat May 12, 2018 12:27 pm
Those tables only have 10 columns for the FN2 & FD2
myuser
Post
by myuser » Sat May 12, 2018 3:42 pm
Hondata wrote: Sat May 12, 2018 12:27 pm
Thanks, for the heads up. :)
