What engine "Load" is it when cranking or starting the engine?
G. Wiffington
Post by G. Wiffington »
This might be a dumb question but, regarding the Low, Medium, & High "Load" tables under parameters what load would it be when you are first starting/cranking the engine?
I was unsure if it would be considered High Load because the engine is just starting or would it be considered a Low Load since the car is stationary & not moving.
Re: What engine "Load" is it when cranking or starting the engine?
It is low load as there is no load on the engine.
G. Wiffington
Okay thanks.
crluver123
Post by crluver123 »
somewhat on topic, what determines the definitive difference between low/high load, and low/medium/high load in the compensation tables? Seeking a specific measurement unit and value
G. Wiffington
The reason I was asking about this was because on my tune it was way too rich in some spots. When the temperature outside
was very hot & I shut the car off it had trouble starting because the map was so rich.
I readjusted my map accordingly & have not had a start up issue since.
crluver123
crluver123 wrote: Thu May 17, 2018 9:34 pm somewhat on topic, what determines the definitive difference between low/high load, and low/medium/high load in the compensation tables? Seeking a specific measurement unit and value
I would still like to know the answer to this
