Boost Control Solenoid Connector
DC5teggi
Post by DC5teggi »
Just thought I would share this for anyone who may be interested.
Per the recommendations I gathered on this forum and others, I planned to wire my boost control solenoid on my 2003 Acura RSX Base (K20A3) to the purge valve wiring. Rather than cutting and splicing, I took a gamble on an alternate approach.
Ballenger Motorsports sells two connectors that appeared to be the same size as the RSX purge valve. I purchased pigtail connector CONN-85746 and can confirm that it mates properly with my stock wiring. See attached for confirmation (my retaining clip snapped off long before I tried this, but the connector would fit just fine if it was still there).
Below is a direct link to the one I purchased, for anyone interested.
https://www.bmotorsports.com/shop/produ ... ts_id/1725
Hope this helps someone!
2003 Acura RSX - K20A3
PND ECU with K-Pro v4
Re: Boost Control Solenoid Connector
Good information, thanks.
