CN2 Port
7rrivera7
CN2 Port
Post by 7rrivera7 »
I have a customer who wants a bluetooth connection with his OBD1 ECU and S300v1 board. The bluetooth adapter connects via the CN2 port but obviously is being used by the S300. Is there a passthru connection to the CN2 port within the S300 board which I can tap to run the bluettoth adapter?
Re: CN2 Port
No, Your only option will be to upgrade to the v3 s300: https://www.hondata.com/downloads/s300v ... e_form.pdf
7rrivera7
Re: CN2 Port
Post by 7rrivera7 »
Ok - do you have the pinout for the external connector on the V1 board?
Re: CN2 Port
What external connector?
7rrivera7
Re: CN2 Port
Post by 7rrivera7 »
Re: CN2 Port
Those are not for use with anything external.
7rrivera7
Re: CN2 Port
Post by 7rrivera7 »
Ok, can you explain what they are used for?
Re: CN2 Port
Programming and testing the S300.
7rrivera7
Re: CN2 Port
Post by 7rrivera7 »
Thnak you.
You can lock this post if you want.
