Adding Boost By Gear
2x0
Post by 2x0 »
I have a newer S300 V3 that was upgraded last year, without boost control components.
What all do I need to be able to set up boost by gear for when I go to the dyno?
'91 CRX, B18c1, T3/T4, 17psi on e85, FIC 1000cc's, S300 V3 P28
Re: Adding Boost By Gear
2x0
Post by 2x0 »
Thank you. After researching I had found most of this info as well, sorry for not taking more time to look before posting.
Question on the 4-way Mac valve. It looks like most commonly used is a 46 series valve. I happen to have 45 series valves available to me and was wondering if these will work? It looks like the only difference is the flow rating, max cv of 0.15 for the 45 series vs. 0.30 for the 46 series.
Thanks!
That valve may not flow enough, you would be better off getting the solenoid we offer.
