Log: Domain error
Betzmotorsport
Log: Domain error
Post by Betzmotorsport »
Hi
I can download from my ecu to kpro with 4.3.5 but when i start datalogging (F10) then pop up hundrets of error windows with the Message „log : DOMAIN error“.
What is the problem? Some months ago all was fine, but now this problem. Is it a problem with the new update?
Re: Log: Domain error
Can you post a screen shot?
Betzmotorsport
Hope you can see it attached
Have you uploaded the calibration back to the KPro with the new version?
Betzmotorsport
Yes, but the same problem..
What is the serial number that is on the K-Pro board?
Betzmotorsport
Serialnumber is 44525
Can you please post your calibration so that we can take a look at it.
Betzmotorsport
Which calibration do you want to see?
The one you are running.
Betzmotorsport
Sure, I hope you find something
Where did you get this calibration?
This is because you have negative values for the voltage offset on your analog inputs. Remove the negative value and it will not give the error.
Betzmotorsport
you are right!
with no negative values for the voltage it is working..
special, because I never changed it since last season and last year it worked. I think it is since I changed to update 4.3.5
