S300 Shifting Problem
jackyft
Post by jackyft »
Dear All,
I have tried to install 4 Civic here w/ Hondata S300 v3. Both of them report to me that when they shift from gear 3 to 4 , 4 to 5. It will have a little bit delay and lost power for 0.5 to 1 second. I tried to modify the setting of TPS tip. But still no luck. Do there any setting I can try? or I was mis-config in somewhere?
Attached w/ the S300 files for your reference.
Thanks in advance.
Jacky
Re: S300 Shifting Problem
that datalog does not show any 3-4 or 4-5 gear shifts.
jackyft
Post by jackyft »
Sorry, for this car, the problem happen even 1 to 2, 2 to 3. If nothing found, I will capture another log today about the shifting problem. Thx in advance.
without a wideband reading it is impossible to see what the fueling is doing.
jackyft
Post by jackyft »
Actually, I have a wideband on it. but at that moment, the AFR is not good.
Anyway, I will collect a new set of data from those cars and upload again.
Thanks for your kindly help!!
