ECU Type for DC5
BevanIMP
ECU Type for DC5
Post by BevanIMP »
Afternoon,
I own a race DC5 which originally was built as a race series for a single make series in Malaysia.
It runs with a Hondata ECU with the K-Pro installed into the ecu labelled 37820-PPA-A07. I know the ecu is not from a Civic or DC5 ?
I'm having running problems and thought I would update the ECU and K-pro to the latest version. What do I put in it please ?
Could someone also confirm what lamba sensor I should run ?
The ecu has the number 590-59446-090026 on it.
Any help would be appreciated
Jonathan
Re: ECU Type for DC5
If you do not have the calibration it is currently running then you will need to start with a base calibration closest to your setup and then begin tuning on the dyno from there.
You must use a primary O2 sensor form a 02-04 RSX or DC5 R.
