Honda Civic 2017 Steering ECU
vadbut
Post by vadbut »
Hi,
I was wondering if you offer any products to modify the EPS (electric power steering) ECU for Honda Civic 2017 or Acura ILX 2016 (which I assume is the same)?
If not, do you know if there are any resources online that can help me to reverse engineer it and alter the firmware?
Re: Honda Civic 2017 Steering ECU
We do not offer anything that will change how the steering works. I do not know of anyone that does.
Prowler
Post by Prowler »
I've Recently installed the kpro v4 on my 2002 ctr (ECU PRA ) and the EPS is not working....Is there a particular setting I can use, am I suppose to chk a box or something ?
The ECU does not control the EPS.
Prowler
Post by Prowler »
OK...Thank you.
Prowler
Best Base map for K24
Post by Prowler »
Can someone advice me of the best cal for my K24?
Am using a K20 CTR head.. With a K24 block..with forged internals (Piston, Rings, Eagle Rods and APR studs CAI and A full 2.25 Cat Back)...Am also using the Kpro v 4 for the PRA, with an AEM XSeries 0300.
