blue tooth cut out
Bulldogk20a
blue tooth cut out
Post by Bulldogk20a »
First post : I have hondata in my ep3 with dc5 type r power train, i have a 9" tablet that i connect to blue tooth so i can monitor my gauges, since my last update (6 weeks ago), the gauges will freeze up periodically and then work again. when its lets use the term "frozen" ive tried shutting off my tablet and connecting another device, and that different device will display the same gauges "frozen" with the same readings, so i know its not the device. But the car always runs the same and if i connect with a cable it works fine. anyone help?
Re: blue tooth cut out
Try unplugging the USB form the ECU and removing the key, then plugging it back in and turning it on.
