New Flaspro user, Ecu NOT Detected HELP
Mike37650
Post by Mike37650 »
Hello, my name is Mike, im a very first time Hondata Flashpro user, i did everything correct and exactly like was asked of me, everything worked great until its time to Lock Flashpro to my car, It NEVER finds my VIN to Lock it, it says OBD is Connected but wont detect my ecu to get my vin. Please help me.
I have a 2005 Acura TSX 6speed.
Re: New Flaspro user, Ecu NOT Detected HELP
The 05 TSX requires an ECU swap and adapter cable.
https://www.hondata.com/products/flashp ... -2004-2006
What FlashPro do you have? Have you swapped ECUs and installed the CAN adapter to the OBDII port?
Mike37650
Post by Mike37650 »
I have FlashPro TSX-US-90787. And no i have not done anything to my ECU or anything. I bought the Flashpro NEW from NoLimitMotorSport and it didnt say anything about needing a different ECU. It actually says Plug and Play, also says No ECU modification required.
https://www.hondata.com/products/flashp ... ?filter=15
Our website clearly states that you must use the 07-08 ECU and an adapter cable.
