No spark help please
MrWr6ght07
Post by MrWr6ght07 »
I'm not getting no spark from dizzy. I replaced CPR harness and dizzy both new different factory engine harness eg civic everything is obd1. My CPR box lights up as it should power and sync fully lit ignition flashes when turning motor over. Ecu has the q37 installed I checked and verified it. Purple altc wire to a16 Power to a25 and ground to a23 both soldered yellow and red wire to a21 I spliced in to existing wire because was unsure how to remove wire and add ICM wire. The two wires that goes to the dizzy plug on harness I soldered power wire to the black/ yellow and tach wire to the blue wire. Any help is appreciated.
Re: No spark help please
Have you tried your CPR box in another vehicle that is running the CPR?
