cant get afr on datalogs
james wheeler
Post by james wheeler »
so my laptop that I had done all my callibrations and data logging on has died a death but everything was set up. iv recenty up graded the fuel system but kept the injectors and fuel pressure the same to try and avoid running to lean. but with my new pc I cant remember how to get the true afr (which I can get up in the display tab under anolog1) onto my data logs it just show my target afr of about 14.7 in the closed loop tab of the logs.
please help, its getting on my wick
Re: cant get afr on datalogs
Can you post your calibration and a datalog made using that calibration please?
james wheeler
hi thanks for the reply, managed to sort the issue in the meantime. had to check a box in parameters.
