AEM 30-0300 Wideband Cal for closed loop
blwncr
Post by blwncr »
Hi, Can you please tell me when i will be lucky enough to be able to run closed loop lambda with my AEM 30-0300 Wideband.
As far as im aware there is no Calibration set in the analog.
ATM i are running it as a custom setting to log but would really like to run CLL.
Re: AEM 30-0300 Wideband Cal for closed loop
Does this use the same calibration information as any of the existing widebands in the software?
dickamusmaxamus
Post by dickamusmaxamus »
Kinda related question...?
I wired the white wire of my 30-0300 to the ANALOG-0 on the KPRO.
I think this is how that's setup but I'm not 100% sure.
dickamusmaxamus
dickamusmaxamus wrote: Mon Jun 04, 2018 2:01 pm Kinda related question...?
blwncr
Post by blwncr »
Spunkster wrote: Mon Jun 04, 2018 9:55 am Does this use the same calibration in formation as any of the existing widebands in the software?
I don't know, that's why I am asking you?
As far as I am aware there is no calibration for this wideband. In another post I read that you were working on making a calibration to suit the AEM 30-0300 in a future firmware update.
Any idea how soon this might be?
What is the calibration information required for this wideband?
blwncr
Post by blwncr »
Sorry I must be wording it wrong.
Under the analog table there is no conversion look up for my wideband. AEM 30-0300
Can I just use one of the ones already there so I can run in closed loop.
My map is very good already but I would like to run closed loop. From my research my wideband isn't yet able to be used to run CLL?
fonzeka
Post by fonzeka »
You are asking questions about AEM products to Hondata, normally you do your own research or ask the actual manufacturer :)
Compare the scaling table on your wideband to the ones available in kmanager http://www.aemelectronics.com/files/ins ... 0-0300.pdf
If you find one that's the same you can use that one otherwise ask Hondata nicely to ad yours.
