Need Basemap for turbo GSR please!!
Coltonmiller22
Post by Coltonmiller22 »
I’ve tried all the closest turbo gsr maps in the vault none make my car start! Please help I’m new to hondata not really familiar with what I’m doing. Any help would be greatly appreciated!!
Info; 99 integra gsr swap in 94 Honda Civic Cx.
Turbocharged to4e set up eBay 57 trim.
Dsm 450 black top injectors
Skunk2 pro series intake 70mm tb
Stock Map, block, head.
Headstuds
P28 hondata sc300 v3
Please someone help. It’s getting spark, fuel, and cranking just not enough to turn over it seems like. It starts on starter fluid.
Things checked;
Compression-good
Timing-in time
Fuel- good all injectors pulse.
Spark- good, all cylinders get spark, plugs brand new gapped to .22
Dizzy- good brand new coil and icm
Grounds- all grounds are perfect freshly replaced. Ground on thermostat housing is also great and freshly cleaned.
All fuses have been checked and no burns.
Main relay is also great.
Fuel pump is great and primes healthy.
Cel is on doesn’t blink. (Known for ecu but the ecu is perfectly fine I have seen zero burns or issues within it)
Someone please help I’ve tried to list everything I can.
Re: Need Basemap for turbo GSR please!!
Are you using a resistor box with those injectors?
Coltonmiller22
Spunkster wrote: Mon Jun 11, 2018 9:28 am Are you using a resistor box with those injectors?
Yes sir!
Who socketed the ECU? HAs J12 been removed?
Coltonmiller22
Spunkster wrote: Tue Jun 12, 2018 11:01 am Who socketed the ECU? HAs J12 been removed?
Had a guy who’s been socketing ecu’s for awhile do it. J12 has been remove I have verified it.
Did he test it after socketing it with the s300?
Coltonmiller22
Spunkster wrote: Tue Jun 12, 2018 4:01 pm Did he test it after socketing it with the s300?
Yes he did.
2000ebpsi
Post by 2000ebpsi »
Here is my base map for a turbo gsr im running precision 1000cc injectors and speed factory 4 bar map sensor so you may have to change those if your car doesnt start or you dont have those parts
