Traction Control installation South American Civic Si
af.orozco
Post by af.orozco »
Hi, greetings from Colombia South America
I recently purchase your TC and I’m trying to install it, the color codes on you manual doesn't match the ones on my car but that not a problem since I’m able to trace the cables and identify the color from each sensor, however I’m not sure we’re the orange cable has to be conected. Base on some other research on 8th gen forum it says it has to be conected to the A23 pin on the ECU. ? Also the electrician that is helping me it’s telling me that my car has Hall effect sensor, so I’m in doubt. Really appreciate if you can help me.
Re: Traction Control installation South American Civic Si
What year is your vehicle?
af.orozco
Post by af.orozco »
2008 Civic Si Sedan
The orange wire must go to one of the 2 inputs you select in the traction control section o f the calibration window in FlashPro manager.
https://www.hondata.com/help/flashpro/e ... ectors.htm
af.orozco
Post by af.orozco »
Thanks for you reply, any way to determine what type of abs sensor I have ? Hall effect ? Active ? Thanks
You have active sensors.
