Launch control fault
Denis_RSX
Post by Denis_RSX »
Hi guys.
Acura RSX'05 and K-pro 4 generation, Honda traction control.
I want to activate launch control in car, turned in calibration clutch switch "always on" and 2700 rpm. Launch control did not work.
Then I connected the clutch switch to the E22 ECU following the example
http://forums.clubrsx.com/showthread.php?t=748200
I checked, when pressing the clutch, in the wire voltage of 12V.
Then I turned in calibration clutch switch "E22 brake switch (12v= on)" and 2700 rpm. Launch did not work.
What could be the problem?
Thanks!
Re: Launch control fault
Please post your calibration and a datalog made with that calibration that shows the problem.
Denis_RSX
Post by Denis_RSX »
Here my calibration and a datalogs ( 1 -without moving; 2-with start).
Thanks!
Have you tried inverting the input?
Denis_RSX
Post by Denis_RSX »
Spunkster wrote: Thu Jun 14, 2018 9:54 am Have you tried inverting the input?
I fixed the Launch control.
Burnout rev limit to "allways off" and Launch control became active.
ethnick
Post by ethnick »
I also followed the steps from that write up for wiring in the clutch switch to E22. Tapped into the clutch switch power wire and ran it to the ecu end of E22. However mine is always active according to the sensor list.
My clutch switch is working as I cannot start the car without depressing the clutch. But when logging with KManager, the brake switch sensor is either always on or always off (if invert input is toggled). Pressing the clutch never seems to change the input to the ecu.
Then there may be a problem with the clutch switch. Test the switch and see if it is working as it should.
mad42
Full throttle settings
Post by mad42 »
Hi the clutch switch it doesn't work i plugged on the pin out e29 can help me some on with that?
How exactly do you have it wired
