changing max boost amount in graph window
dogmoo
Post by dogmoo »
Is there any way to change the max boost setting in the graph when viewing a datalog? it's set to 100 psi so barley even shows as a blip of a line when viewing on the graph. Thanks
Re: changing max boost amount in graph window
Right click the MAP in the sensor list and you can change the min and max values there to be able to see it more clearly.
