Cpr help
phongher
Cpr help
Post by phongher »
I’m sure I wired it correctly don’t know why I’m having power and ign light on at the same time. Got the s300v2 sync box checked, when I crank it sync light flashes like it should. Tried the s300 with a different car with cpr so I’m sure it’s not the ecu. Checked wiring a over and it’s good. Took out coil and rotor off the dizzy. What can it be. Seems like I’m not having spark . I’m using k20 coils Image
phongher
Re: Cpr help
Post by phongher »
That’s with just ign on
Re: Cpr help
Have you tried this CPR box on the other working vehicle that has a CPR?
phongher
Re: Cpr help
Post by phongher »
Not yet but will try when my friend get his car back from tuning
phongher
Re: Cpr help
Post by phongher »
Spunkster wrote: Mon Jun 18, 2018 11:52 am Have you tried this CPR box on the other working vehicle that has a CPR?
Ok so I did try the box on my buddies car his box have power light on and IGN flash (I think) when cranking. Mines have the have IGN and power on at the same time. Maybe something is wrong with the box?
Re: Cpr help
Send an email to support<at>hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
include a link to this thread
phongher
Re: Cpr help
Post by phongher »
thanks alot just sent you a email
