Fresh installed group n map
lbmarsh
Post by lbmarsh »
Hi Guys,
Just wondering what the opinion is or if there's any e-tuners that can assist with my fladhpro, group n map is installed and the car is now running very lean at low revs (don't have data log to hand atm) and under full acceleration it feels sluggish and hesitant and some had an instance of a cough this eve 4th gear 4500 revs.
Fn2 running hks rsk and tegiwa catback.
Is it worth taking it to eurospec or could someone give me some advice
Cheers guys!!
typer86
Re: Fresh installed group n map
Post by typer86 »
I can tune your car via e-tune.
Pm me if interested.
I have tuned 3x fn2 with similar mods like you.
BR
goodwoodone
Post by goodwoodone »
Hi typer 86 sorry to jump on this thread but im in need of a emap for my FN2 i have a Gruppe M intake piper header with CAT removed and a TODA catback exhaust.
I will be getting a dyno run later but want it to make a good start now.
Gareth
lbmarsh
Post by lbmarsh »
typer86 wrote: Fri Jun 22, 2018 12:52 am I can tune your car via e-tune.
BR
Hi dude, won't let me pm you for some reason, but yeah pretty keen to get it running better, drop me a message with an email address in and I'll get in touch, cheers.
lbmarsh
Post by lbmarsh »
After a week or two of driving and some better fuel it's stopped coughing but still feels a little bit naff, is there a good to doing the fueling so I can have a crack??
typer86
Post by typer86 »
lbmarsh wrote: Mon Jul 09, 2018 5:08 am After a week or two of driving and some better fuel it's stopped coughing but still feels a little bit naff, is there a good to doing the fueling so I can have a crack??
No I don't think so... Most cases it is solved if the engine is tuned. The base map is only a base map and I do not recommend to drive this every day...
typer86
Post by typer86 »
goodwoodone wrote: Tue Jun 26, 2018 4:40 am Hi typer 86 sorry to jump on this thread but im in need of a emap for my FN2 i have a Gruppe M intake piper header with CAT removed and a TODA catback exhaust.
Gareth
I can tune your engine. I have tuned many FN2 before
- 2x NA FN2 (none turbo/supercharged)
- 1x turbo FN2
- many supercharged FN2 :D
- 1x K20z4 head/K24 block frank
All projects are extrem fine tuned without bumbs in VTC, Ign calibration. Additional IAT, ECT compensation tables will be adjusted so the car shows perfect lambda value each temperature situation/saison...
goodwoodone
Hello Typer86 thanks for the reply would be interested in the tune how would you normally proceed I'm busy at the moment but if you need me to do data logs to get an idea how my car is running that would be good next week.
Gareth
Cranney
Post by Cranney »
typer86 wrote: Thu Jul 12, 2018 5:27 am
Gareth
- 1x turbo FN2
Typer86 can you send me a pm, I need a e tune
typer86
Post by typer86 »
PM is out.
typer86
Post by typer86 »
goodwoodone wrote: Fri Jul 13, 2018 5:32 am Hello Typer86 thanks for the reply would be interested in the tune how would you normally proceed I'm busy at the moment but if you need me to do data logs to get an idea how my car is running that would be good next week.
Gareth
E-TUNING process
The e-tuning process is easy.
#1 Each e-tune customer will receive a OneDrive link.
> In this folder in the OneDrive the car calibrations will be updated from me.
#2 Each drive cycle you will upload into a sup-dir inside the OneDrive named with the calibration-version so I can map your datalog to the calibration.
#3 You will receive my mobile number for whatsapp so we can discuss all details, changes and a lot of more :-)
(e-Tuning consume a lot of time so I can not do it for free)
If you are interested, PM me.
BR
typer86
Post by typer86 »
If this come up, prim oxy sensor is bad or fuel pump is going to die...
The first one I have seen few month ago on a supercharged FN2.
First 3 gears are OK, then the mixture is going lean until lambda 0.85/0.87 in cause that the ECU would like to switch back to closed loop and does not revving high.
Crx_AA
Post by Crx_AA »
Hi,
do you have the group N map to K-Pro?
FlashPro calibrations cannot be used with K-Pro.
