Target Lambda table
skaterguy1986
Target Lambda table
Post by skaterguy1986 »
Is there any way to change the values in this table? I'm asking because I'd like to run slightly lean at idle and cruising while using closed loop fuel control.
Thanks.
Re: Target Lambda table
This can be changed on the closed loop advanced tab in parameters.
2x0
Post by 2x0 »
I thought these were controlled by going to Options > Settings > Target Lambda
The closed loop advanced parameters control what your wideband will try to actually adjust to when driving in closed loop.
'91 CRX, B18c1, T3/T4, 17psi on e85, FIC 1000cc's, S300 V3 P28
Those settings will not have any effect on your closed loop operation. The settings I have mentioned are what control this.
skaterguy1986
That table in the closed loop advanced window is a bit too broad of an adjustment. I wanted to go into the tables window>"show target lambda" and adjust the idle and light throttle cruise so that it targets something a tad leaner like 15:1 but when I tried to alter the numbers it just adjusted the fuel value.
