K24 into a VW Baja
SoCalBaja
K24 into a VW Baja
Post by SoCalBaja »
I just picked up a K24A RBB-2. The JDM shop gave me a ECU. It’s number 37820-PND-J01. Can that be reflashed to work with a kpro system on this engine? I plan on using a RSX Type S engine harness and Rywire power harness. Does all this sound right for a stand alone system in a VW Baja Bug?
Re: K24 into a VW Baja
Unfortunately that ECU is not compatible with K-Pro. What transmission are you using with this?
SoCalBaja
Post by SoCalBaja »
I called HASPORT.COM today and they said it would work. What ecu do I need then?
I have a K24 RBB-2, RSX-S wiring harness.
I’m using the VW tranny. I’m putting the K24 in my 1970 VW Baja Bug.
SoCalBaja
Post by SoCalBaja »
Spunkster wrote: Thu Jun 28, 2018 12:02 pm Unfortunately that ECU is not compatible with K-Pro. What transmission are you using with this?
It says PND ecu.
SoCalBaja
Post by SoCalBaja »
Will this one work?
The Japanese PND will not work. The US PND will work (A08).
Kawikilla
Post by Kawikilla »
Can you explain to me how you’re putting the ka on a vw trans? Is there an adapter plate out there? Very interested in do that swap on my 70s sandrail, do you have a social media that has finished swap I can reference?
