Hondata mobile can't find kpro
adeeb1395
Post by adeeb1395 »
Hondata mobile can't find kpro. it hardly finds kpro. But once it finds then there is no problem finding it after that, until the battery is removed.
when the battery is removed the next day is same again!(i need to remove the battery as its a swapped car and battery doesn't have a permanent place to sit for now). Tried couple of time turning the engine on and off several times but no luck still can't find. Shows the empty blue screen only when i press connect.In two weeks i was able to connect with the app only 2 days. i configured the bluetooth in the kmanager, registered the mac address there.After that was able to connect, so the mac address is ok confirmed.
what can be the problem?
my phone is iPhone 6+ ios 11.4
Re: Hondata mobile can't find kpro
How is the car being driven if there is no place to keep the battery?
adeeb1395
Post by adeeb1395 »
not driving it now just did the swap and the car is in for dent paint.
Wait until the battery is properly mounted and see if the issue goes away.
