Car started w/o coolant added coolant now no start. Help!
9k_Dre
Post by 9k_Dre »
Hey Hondata,
I recently finished my turbo build.
Precision 6262
DW 1000cc injectors
Aeromotive FPR
Stock motor
KMOD turbo manifold and exhaust.
-6an fuel return
Currently open exhaust
I put everything together and went to start her up w/o coolant. The car started up no issues and idled fine. I let the car idle for about 1 minute before shutting her off. The following day I filler her up with coolant and went to bleed the system, the car cranks but refuses to turn over. I am getting fuel pressure (60 psi at the rail). I checked my plugs and I have spark, and timing marks line up perfectly. Car ran and idled fine yesterday what could the issue be?
Re: Car started w/o coolant added coolant now no start. Help!
Is it actually spraying fuel?
9k_Dre
Post by 9k_Dre »
Yes, the injectors are spraying.
check all wiring and fuses. Also try datalogging while trying to start and see if there is anything obvious in the datalog.
9k_Dre
Post by 9k_Dre »
I checked every last fuse and wiring. I'll datalog it while cranking and post to see if there is anything strange going on.
9k_Dre
Post by 9k_Dre »
Can you take a look at my datalog and calibration to help me figure out what it might be? I will post them tonight when I get home from work.
Thank you.
