boost controller s300 obd1 pr4 help
Goerbond
Post by Goerbond »
i was reading the boost controller install on the s300 install softwre and it say that the pr4 ecu doesnt need to have any mods done to it so can someone please clear this up for me do i need to gt it chiped for the function to work and how do i go about hooking the controller up also cantnot find how to retard timming for boost where is this function on sman software thanks
Re: boost controller s300 obd1 pr4 help
You must look inside your ECU to see if the components are installed: http://www.hondata.com/help/smanager/bo ... tsub=boost
You can adjust the timing in the timing tables under boost conditions.
