Problem putting into gear after upgrading to 2.6.6
codenamezero
Post by codenamezero »
Hello,
Been running my Integra fine for 2 years using S300 v2.5.3
This morning I decided to update the software this morning, loaded the old calibration file from 2 years ago.
"Seems" ok and uploaded it to my ECU.
But as soon as I put it in reverse (to get out of my garage, or in gears) and try to give it gas, it dies.
Any quick "check list" or "major change" that I need to verify when going from 2.5.3 to the latest v2.6.6???
Edit: Also, why is Disable Knock Sensor checked by default?
Re: Problem putting into gear after upgrading to 2.6.6
Without your calibration and a datalog showing the issue it is hard to say what it might be?
What is the serial number on the s200 inside the ECU?
94 teggy
Post by 94 teggy »
mine had a similar problem mine would go into gear and would go past 2000rpm in any gear and would want to die found out it was the tps that wasn't calibrated correctly not sure in your case but thought id share my experience
