02-04 KPro'd ECU to 05-06
geluzi
Post by geluzi »
Hello,
I am new here in the forums so if you can bear with me, that would be great!
I recently acquired an already KPro'd 02-04 ECU. I have a 05 RSX Type S and I have a K24A2 bottom end. Plan is to frank swap my Z1 top end and K24A2 bottom end. The only thing I need is the KPro so I can complete the swap. For what Ive known, I need a 05-06 adapter harness for the 02-04 KProd ECU to work on my 2005 RSX-S. Problem is, my dealer said Hondata won't sell the adapter harness separately. Is there any solution to this? Thank you!
Re: 02-04 KPro'd ECU to 05-06
Tobydc5
Post by Tobydc5 »
Spunkster wrote: Mon Jul 23, 2018 11:49 am What is the serial number that is on the K-Pro board inside the ECU?
If I were to buy an adapter harness and a non kprod ecu (02-04), how much would it be to send it in to get programmed by hondata for my 05-06.
This is not done separately. It is a complete package sold with the adapter, K-Pro and ECU modification.
