Injectors Cut w/o commanding.
terrorista
Post by terrorista »
Hi Guys,
I dont know why ... But this calibration is cutting the injectors like on launch control.
BTW, i've recheck all the calibration again and, still the same condition.
No clue about what is going on .. We've check the clutch switch and etc ..
When Getting up a basemap, still got the same cut. When returning ECU to Stock, the car runs OK.
Attached the calibration and the Datalog.
Thanks for advising.
Re: Injectors Cut w/o commanding.
Where in this datalog are you seeing this happen?
terrorista
My Bad Guys,
Wrong datalog. here the correct one. Bellow the point of cut.
datalog0000.fpdl
You have a number of error codes which you should try to resolve before troubleshooting this issue further.
devan
Post by devan »
It appears the car is in limp mode. I'm pretty sure your Check Engine Light is on. Have the code(s) scanned and we might be able to help!
Você fala português? Sua "luz do mecanismo de verificação" está acesa?
Cheers,
~D
8th Gen Civic Enthusiast and K Series Connoisseur
terrorista
Thanks Guys,
Ill check it out before going ahead!! Yep .. I do Speak portuguese! lol !!
Cheers,
